Aktuelle Zeit: 19.04.2018, 20:03
Ein neues Thema erstellen Auf das Thema antworten  [ 2 Beiträge ]
 Betreff des Beitrags: A1 or CC4
BeitragVerfasst: 21.08.2017, 17:51
Hello.
I'm using A1 as preamplifier along CD2-3, T1 and P3 with hidden POWER amplifier Mitsubishi DA-A15DC (very powerful), running Vandersteen 1B speakers.
Would CC4 make any sound improvement over A1 as preamplifier.
Regards Marko
 Betreff des Beitrags: Re: A1 or CC4
BeitragVerfasst: 22.08.2017, 12:58
Dear Marko,
there should be a difference - but can one hear it?
Most probably the quality of the sound depends on the condition of the pre amp.
A revised A1 will sound better as a CC4 which never has been watched after.
Andreas wrote this:
viewtopic.php?f=3&t=5127&hilit=Klang+A1
Uli wrote that - well, after he did a four weeks'(!) revision:
viewtopic.php?f=38&t=600&p=3445&hilit=Klang+A1#p3445
Uli hat geschrieben:
Der Klang ist allemal klarer als mein vorheriger A1 und selbst meine Frau erhörte den Unterschied.
Maybe the best sound quality you would get with a revised A2, which has a very good pre amp stage with a well-balanced acoustic pattern ...
Conclusion:
You will have to try for yourself, sorry to say.
Yours, Gereon
_________________
