TG1000 height of the tape spools
helloradio
#1 Beitrag von helloradio » 04.09.2015, 18:30
hello
What will be the proper way to adjust the height of the tape spools so the tape will be exactly in the middle of the spool?
thank you in advance for your help.
Darius
ps is it normal that motors and other parts for example rectifier bridge on control board are so very very hot?
gyrator
Re: TG1000 height of the tape spools
#2 Beitrag von gyrator » 04.09.2015, 19:04
helloradio hat geschrieben:hello
Darius
Hi Darius,
To adjust the height you have to use washers. You have to remove the plastic holder of the spools in advanced. The washers can be placed under the the plastic holder.
helloradio hat geschrieben: ps is it normal that motors and other parts for example rectifier bridge on control board are so very very hot?
Yes! It's normal!
Regards
